MTribe
Can anyone confirm that a gear reduction starter on a TR6 is tolerant of the bevel of the ring gear facing the rear of the car?
That is, the bevel on the ring gear is facing rearward and the current solenoid starter engages from the front. Everything worked fine until I rebuilt the engine, and upon assembly, the starter pinion doesn't engage every third time or so.
I was considering replacing the ring gear to get the bevel on the right side, but have heard rumor a modern gear reduction starter could work fine with the bevel going the wrong way. If anyone could confirm I'll order one up! Sounds like it's backward on virtually all TR6s.
Thanks!
Thanks!
