Gear reduction starter compared to original
tdskip
The new TR didn't starting consistently, and after eliminating electrical issues it appears that the starter was simply worn out.
Thanks to everyone for their ideas on sourcing a new unit - I ended up going with BP Northwest. Nice folks.
Here is what the new one looks like compared to the original.
R
RonMacPherson
speaking of which(gear reduction starters)..
A couple of hints. When you hook up the starter(after bolting it to the engine) make sure you do not get a flash of spark by hooking the wire to the major post.
Ideally you should disconnect the battery when working on the starter. However, the wires and clearance on the starter on a 6 gives plenty of room.
If you do get a spark when hooking up the juice(either at the starter or the battery, whichever is last to hook up) STOP!
I've seen two starters in our British Car Club members cars in the last couple of years come shorted internally.
Take off the end cover and you can see the main contact, should be installed and not touching the body. If it is touching the body, loosen the bolt and reposition it properly.
Later on down the road, after many many starts when you go to crank and this starter doesn't go to your friendly Napa store and get the Hitachi starter contact kit. Used to sell for about 16 dollars. And it can be installed easily by anyone(even you cuz, much as you disclaim mechanical ability).
T
tdskip
Hi Ron - thanks for the tips.
I disconnected the battery, removed it from the car, locked it in a box, and dropped it off a block away until I had everything connected. <grin>
Only slight curve ball was the old wiring was spliced at some point and looked flaky so I replaced it.
The new starter seems to work OK - it really cranks the motor over.
Thanks for the Hitachi contact kit idea - good to know!
G
The big issue installing these babies is when you have headers. They can be a real pain to install. One needs to make certain that the type of starter purchased is like the one TD shows in the above photo, with a full radius of holes for clocking the starter in any position that will make it go for your particular application, I have had to clock mine with the positive lead precariously close to the engine block, but that is the only way I could get her to go in. Another pointer is to wrap your starter with a heat shield to somewhat protect it from the heat of these headers.
DNK
Bill, Part true and part false. I purchased a starter from a eBay seller who swears will fit. In fact is similar to the above one. Even with drilling new clock holes it still would not fit. I ended up getting one from Ted and it is a little smaller than the previous one I purchased. I was able to getTed's to work . So I have a never spun start for anyone with stock or non race headers.
donbmw
Do your self a faver before you installed the starter. The allen head bolts that hold the endplate on have been none to come loose over time. This can be a short time or even over a few years. Take them out and reinstall them with Loctite.
Don
G
Don, Ted supplied me with a high-torque starter that was designed to fit the TR250, and also supplied me with the cast aluminum bracket to make it fit my TR6. He bent over backward to accommodate me. Grumpy guy that he can be.
DNK
Bill, that's why I said the 1 that Ted's sells works for our hard to fit headers. A lot don't.
The bracket is from aTR3 I believe. Did you have to do some mods to the bracket?
G
I had to file it quite a bit on the outside. After an hour of cursing, I got it. Works great....
DNK
I used a dremel tool, About 5 minutes including the sanding. :devilgrin: :jester:
So ,like I said, I have a brand new hi torque that I will let go cheap here.
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D Gear Reduction Starter Austin Healey 15
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
J TR2/3/3A Need opinion on gear reduction starter for TR3A Triumph 23
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
davidb AH 3000 gear reduction starter Austin Healey 13
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
Willie_P TR4/4A WIRING question: gear reduction starter Triumph 3
H gear reduction starter cross reference Austin Healey 12
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Gear Reduction Starter comparison Austin Healey 7
NardisCNC How do I wire this new Gear Reduction Starter?? Spridgets 4
H Gear reduction starter motor Austin Healey 9
T 100 4 Gear Reduction Starter Austin Healey 1
Tremelune TSI gear-reduction starter into '65 Sprite Spridgets 12
J Gear Reduction Starter Question Triumph 8
Glen_B Gear reduction starter pinion detail needed Spridgets 2
angelfj1 TR5/TR250 TR250 - gear reduction starter install Triumph 4
King_of_England aftermarket gear reduction starter failure Triumph 10
M Flywheel ,ringgear.gear reduction starter guestion Triumph 4
T Starter for a 1275 - stock or gear reduction? Spridgets 9
MTribe gear reduction starter fix ring gear bevel? Triumph 5
M TR2/3/3A TR3 Gear Reduction Starter Triumph 5
Tronch Gear reduction starter connection Austin Healey 3
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
Darrell_Walker Mounting position for gear reduction starter Triumph 2
VelodromeRacer Gear Reduction starter! Austin Healey 21
T Wedge TR8 Gear reduction starter Triumph 2
A Gear reduction starter Triumph 11
S Who has best price for gear reduction starter? Triumph 9
J Gear Reduction Starter Austin Healey 2
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
F TR6 speedo gear reduction Triumph 3
T TR4/4A TR4A wiring - gear reduction & external solenoid? Triumph 6
T How tell if gear reduction start fits is right? Triumph 2
angelfj1 Gear Reduction Starters - are . . . Triumph 17
TRMark TRF Gear Reduction Starters Restoration & Tools 1
Aldwyn TRF Gear Reduction Starters Triumph 31
DerekJ High Torque Gear Reduction Starters Austin Healey 2
G Gear Reduction Starters Success Triumph 15
D Gear Reduction Motors Austin Healey 1
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
