regularman
Hello all,
I have had this problem several times and it nearly bit me big time yesterday. I went into a curve and the road was a little wet and I had to get hard on the brake and it pulled to one side bad, causing me to spin out and come within a few inches of a guardrail. I have not even pulled the drum off yet but I am pretty sure this is the same problem I have had a couple times before. Does anyone know of a real cure for this? I have tried several things but its not working. One thing I want to do is block off and put some air pressure in at the axle and make sure it blows out the vent on the differential.
Kim
Kim
