Gauges dead after wash
G
Washed her today @ the car wash. Usual outside job w/ a quick spay down of the front crossmemeber and frame rails. Didn't get the engine wet hardly as I was just washing oil off of the frame rails. Didn't shoot electrical stuf either. Shot it from the front underside and P.S as well. Got back in and the gauges and heater doesn't work, everything else is fine. Let it sit a few hours and still the same. All fuses in the fuse box are o.k and a wiggled all the wires going to and from it. Everything seems fine but no worky-worky. Any other fuses somewhere else I need to check? Any ideas? :hammer:
I donb't have a schematic, which color wires go up thata'way?
Thanks
lbc_newbie
I'm gonna agree... here's what I found my first day on the Forum!
"Hey fellow MG Midget/Spridget owners! I'm the friend Dave was asking for. He was nice enough to introduce me to this forum. I would really like to thank you guys for coming through on this! JPSmit nailed it with the fusebox lug and the green wires. As soon as I applied a little pressure, the gauges lit up! Looks like a fuse box is in order. A small piece of foil on the end of the fuse seems to be doing the trick for now. I have EVERYTHING working! Blower motor (thought it was a bad switch), brake lights (thought it would cost a fortune to diagnose), temp and fuel gauges. I'll check the tach when I start it up (carb is on the work bench). Glad to have friends like you guys out here. I'll be in touch as I restore my Midget! THANKS!!"
I've since removed the foil! Cleaned the lugs up with a dremmel tool and life is good.
G
I just cleaned them all up and still nothing. No wipers either.
Just went back out and I got it!
The fuse itself was bad. It wasn't blown, but had come "disconnected" from the inside of the end. Looks like it had been corrding for a while. Both meters had bad batteries and I had to use the test light across both ends of the fuse.
Thanks lbc, I started at the green wires since you told me right where to go.
Serves me right, I didn't have the tool kit in the car when I washed it and didn't have spare fuses in it anyway. Got fuses in it now and it will have an "extra" meter in it when I get some hot batteries. Might just put a test light in it so I won't have to worry about bad batteries in an emergency. Thanks guys !!! I'm already for tommorrow, I just need somewhere to go.
CraigZ
Shortly after I got back on the road with mine I pulled out of the driveway and glanced at the gauges...full tank of fuel. Turned the corner, looked down again and the fuel gauge was heading to "E". Fast. Oh, and no turn signals. No brake lights either I think. Opened hood, spun the fuses...it all came back. I love old cars :smile:
Sarastro
Actually, this is a good case study. I've seen those 1/4" cartridge fuses fail in the way kellysguy describes. The caps are attached with some kind of glue, and it can get crumbly with age and heat, then they come loose. Our cars have plenty of both age and heat, I think.
JPSmit
I also suspect that that they actually can burn out at the joint a little easier. My electrical test #1 is always continuity across the fuses.
waltesefalcon NA Miata gauges Other Cars 16
A TR6 Changing bulbs in gauges Triumph 27
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D Possible Mini Gauges? British Motor Corp 6
Pythias Bugeye [style] gauges in a Box Sprite? Spridgets 13
E Trying to ID some old classic car gauges Restoration & Tools 2
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
P For Sale O-rings for Smith and Jaeger gauges. Other British Classifieds 2
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
P Wanted AH 100-4 Gauges Austin Healey Classifieds 0
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
P AH 100-4 Gauges Austin Healey 0
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
K TR2/3/3A Temperature Gauges Again Triumph 5
Jim_Gruber Speedhut Gauges on sale 15% Labor Day Sale Spridgets 0
S TR4/4A procedure for installing gauges etc Triumph 0
HighAltitudeTR3 TR2/3/3A Gauges...? Triumph 2
mgedit TR2/3/3A O-Rings for TR3 Gauges Triumph 9
Jim_Gruber Another Christmas Present for Bugsy - Speedhut Gauges Spridgets 8
Jim_Gruber Speedhut Gauges- And IGN Warning Lamp Spridgets 16
Jim_Gruber BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale Spridgets 10
T Speedhut [or alternative] gauges for a BJ7 Austin Healey 4
K TR2/3/3A Gauges held in by "knurled Knobs"?...always losing them. Triumph 10
M rebuilt gauges Spridgets 10
jfarris TR2/3/3A TR3 gauge panel and nuts on gauges Triumph 5
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
R TR2/3/3A Gauges for tr2 Triumph 3
K TR2/3/3A TR4A Gauges in a TR3A? Triumph 13
Jim_Gruber Speedhut Gauges Spridgets 12
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
Zitch TR4/4A No dash lights! Or any of the gauges. Triumph 11
DanLewis Illuminating gauges with Electroluminescent tape Spridgets 24
Got_All_4 Wedge Speedo/temp gauges TR7 Triumph 7
B '93 Voyager gauges won't work?? Other Cars 9
D Gauges Spridgets 15
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
T Nissonger info on rebuilding gauges Spridgets 4
M Chart for wire gauges Triumph 9
B Fluctuating Gauges 68 MGB FORUM Navigation Questions 0
B MGB Fluctuating Gauges 68 MGB MG 5
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
abarth69 Wanted Fuel and Oil /water gauges for BN1 Austin Healey 3
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
Andrew Mace Wedge TR7 fuel and temp. gauges not working Triumph 28
HerronScott Why convex/curved glass for gauges? Triumph 11
K Temp gauges on brit race cars? Racing 4
pjsmetana Gauges - 4 & 5 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 3 of 7 complete [pics] Triumph 0
pjsmetana Gauges - 2 of 7 complete [pics] Triumph 10
