Gauge lighting
TimK
I have no lights on my gas gauge and my oil pressure/temp gauge (BN7). There is an empty light socket hanging down from the dash with a red w/white wire coming from the tach light. It would work with a light bulb and the metal ground strap attached to something. I do not see where the socket is to be connected to anything. I assume it is intended to provide lighting to the gas gauge remotely (not connected inside the gauge like the tach and speedo lights.) But how is it attached to anything?
I do not see where the socket is to be connected to anything.----Seek and yea shall find--Keoke- :laugh:
I assume it is intended to provide lighting to the gas gauge-- :yesnod:--------- remotely- :yesnod:
It should be connected inside the gauge like the tach and speedo lights.) :nonod:
There should be a loop which is a portion of the retainer bracket that holds the meter in and allows the socket to also be pluged in to-TMK
I had the gas gauge out in my hand and it has no light socket. There is a metal ground tab attached to the socket that may attach to something else. The gauge has transparent slots around the rim with blue plastic in the windows. I need to hear from a 100-6/3000 Mk I expert.
:shocked:
Yep I forgot you have one of those antique cars. There is a picture of one of those gauges on this forum probably in the archives now., it may help you a bit.
OH! I remember now! The bracket that holds the gauge in includes a funny little loop like portion that holds the lamp socket remotely from the gauge.---Keoke
That's it, Keoke's got it. The light shines in through the slots that you saw. :iagree:
Larry
Yes, I went out and crawled upside down under the dash and discovered the round metal bracket on the oil/temp gauge. It had a burned out bulb which I replaced and that side now works. The round metal bracket is missing on the fuel gauge side and that is why the light socket was hanging down. I will have to fabricate some alternative some day. I tried drilling a hole in the brass tab on the socket and proceeded to rip my finger open with the drill. At least I now have three gauges lit where I only had one before. I never drive the car at night, so it never mattered before, but now I'm trying to fix as many old problems as I can since I'm retired and have the time. I just finished putting in new Heritage Karvel carpet and replaced the headlamp dimmer switch that had never worked for 28 years. The next project is reinstalling my wiper system that I removed after it failed and blew the main fuse. I got a rebuilt motor from England -- the shipping was twice the cost of the motor.
Thanks for hanging in there, Keoke, until you came up with the right solution.
And thanks Larry for your confirmation.
I did fabricate a socket holder based on a photo I happened to find in John Loftus's comprehensive restoration photos. I now have all the lights working.
Way to go!! :yesnod:
Larry
