Merlin63Tr4
Why is the vacuum advance unit in my TR4’s distributor filling up with gasoline?
I was doing a regular maintenance check on my TR4.
As part of that I was checking the vacuum advance unit for leaks, etc with a Mighty Vac and it sucked a fair amount of raw gasoline out it.
The diaphragm of the vacuum advance unit is not punctured (vacuum reading was rock solid) and the car is running like a champ but this raw gasoline in the vacuum advance unit is very puzzling.
Carbs are Z-S CD175’s, the current vac pipe to the distributor is hard plastic, had the same occurrence with the original metal pipe.
D.
D.
Hi Guest!
