gasket question
Order a few other bits that you surely need to soften that $10 hit on the $5 item and get the gasket. The oil pan is just not going to be a good enough natural fit.
Bayless
Morris said:
Sooo... Therefore, I am wondering if Permatex #2 (the black gunk) would be good enough to seal the oil pan. What do you guys think?
on the engine pan, i would install the proper gasket kit.
based on this discussion, i will stay with the designed gaskets along with a small amount of sealant. i want to take advantage of the improved materials and methods we have now to reduce the leaks as much as possible.
i am spending a lot of time cleaning and examining every piece of this car. it would be disappointing if i just put it back together and wasn't able to reduce the number of leaks.
thanks for the discussion and advice ...
An alternative to spending more money, is spending more time (there is never a "Cheap way") and buying the cork gasket material in sheet form and cutting your own!
I will definitely make my own gasket before buying another. As many times as I pull my pan, maybe I can make a pattern or jig so I can just bang out a new gasket whenever I need one. I do have an extra oil pan.
Okay, you can have your thread back now, Fred.
