TR2/3/3A Gasket part way off
Tr3aguy
I got a replacement gasket for the differential and it is way off! Anyone else have this issue??
Geo Hahn
I no longer have my '3 but recall the diff gasket I got from a West Coast supplier was useless - holes simply did not match up.
Easy enough to make my own and use better material while I was at it.
sp53
Yes mine too. I purchased some hole punches from leather hobby store and they helped with making gasket holes nice.
martx-5
As suggested, better off to make your own. The ones you buy, even if they fit, are just too thin. Hard to get them to not leak. The stuff I used is about 0.030" thick and hasn't leaked in years.
Bill Young
We had a similar issue with Austin-Healey gaskets and found if we soaked them in water overnight they seemed to fit much better
Merlin63Tr4
I think someone shipped you a TR4-A IRS diff cover gasket instead of a TR3-TR4 diff cover gasket.
See pics.
M.
Tr3aguy
Tr3aguy
I called and spoke to them. They swore it was right and I just did not orient it the right way. Flipped it every way possible and sent pictures…. Basically they answer was to credit me for the gasket!!? I would rather have one that fits…. Very frustrating. It is almost like they threw up there hands with the why bother attitude. It makes me wonder it they just don’t care or if you have to hit a certain price point before they would investigate the issue. Lesson learned I guess.
Merlin63Tr4
Did you explain to the weenies on the other end of the phone that the covers are different.
The number of holes are the different in the gaskets, 8 holes for the TR4, 10 holes for the TR4-A IRS.
Extra holes in the TR4-A IRS are for some dowel pins, housing is also wider.
Guess customer service/tech service in out the window.
M.
B TR6 Gasket sealer Triumph 1
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
B Bonnet hinge gasket Spridgets 10
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
R BJ8 Cylinder Head Gasket Austin Healey 38
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
B TR4/4A Head gasket won't lay flat Triumph 13
T TR6 TR6 Carb Gasket Sealing Triumph 1
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
K Gearbox Throw-out pin and gasket question Austin Healey 8
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
F Sump Gasket Question Austin Healey 15
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
F Heater valve/tap gasket- Install dry? Austin Healey 10
steveg Strange gasket pieces Austin Healey 5
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
Lin Oil sump gasket replacement Austin Healey 31
vette Valve Cover Gasket Austin Healey 18
Michael Oritt Head gasket question Austin Healey 17
