Nelson
My Sprite was last run back in '73. My restoration is now very near to completion and I am just about ready to fire up the engine again. I just realized that I may have a problem with the gas tank. There was some gas in the tank when I put the car into hibernation but I have no idea how much. When I pulled the drain plug several years ago nothing came out. Now I am concerned that there may be some residue that will come loose when I put new gas in the tank. There is a filter before the input of the Facet fuel pump I have mounted at the tank. Do I need to be concerned about crud creating a problem? If so, do I need to remove the tank and flush it or is there a less troublesome way?
