Thanks for all the help everyone on my gas tank problems. At this point I have sand blasted my gas tank, used epoxy primer, and finished it off with semi-flat enamel. After pulling everything apart, I am glad that I did with the various problems I found. I am waiting on parts from TRF before I put everything back together. In the mean time can someone recommend any type of solution to clean a gas tank once it has been pulled? There does not appear to be any rust, just some crud. Even though I had it plugged while I blasted it, I still managed to get some "sand" inside the tank. I was thinking of just filling it up and agitating it with something like Simple Green, followed up by slushing it around with alcohol before installing it. Any suggestions would greatly be appreciated?
Thanks, Kevin
Thanks, Kevin
