John Morralee
The car is a '63 BJ7 and undergone a complete restore after'rusting out'and standing idle since 1973 1)Gas gauge does not work. 2)There is a slight deflection of the needle when ingnition is switched on i.e current is arriving. 3)The sender in the tank shows a change of resistance when float is operated by hand.4) I understand the balanced coil principle of the gauge(sort of!). Is it worth taking it apart? Can they be repaired?
Hi Guest!
