Gas Dumping Out on Ground Under Car
tony barnhill
Great Pumpkin - R.I.P
So, I'm piddling with my '74-1/2 GT & left the ignition on while piddling...
...the fuel system never pressurized & dumped gas out on the garage floor from the anti run-on valve vent hose (#64 in bottom diagram below)....apparently, once the fuel bowls are full instead of pressurizing the system & causing the pump (brand new) to stop pumping, the pump continues pumping & the excess gas is going through the overflow hose at the carbs (its the unmarked pipe/hose combination connecting the 2 carbs in the top diagram) ending up in the charcoal cannister (#60 in top diagram below) then from there via the run-on valve hose to the cannister (#66 in bottom diagram) through the anti run-on valve (#61 in bottom cannister) & into the anti run-on valve vent hose then onto the floor.
So, correct me if I'm wrong...I've either got float problems (I just rebuilt both HIF-4 carbs) or a leak somewhere in the fuel system that's allowing enough air in the system so it can't pressurize...does that sound feasible? Or, should I focus on what I might have done wrong in the float bowls?
I'd go with the float bowl investigation to start, Tony. If the needle valves properly closed, the fuel pump should have shut off.
Or, there's a problem with the fuel pressure.
Doing the floats on HIF's make you appreciate the HS4 configuration!
Jeff
I knew that - was just hoping I didn't have to remove the carbs again...oh well, tomorrow's another day!
