I have been adding in-line fuses to my BJ8 as follows:
Fuel gauge 5A (3AGC)
Wiper 15A (10AGC)
Brake/Tail Light 5A
Number plate light 5A
Fuel pump 10A(7.5AGC)
Heater fan 7.5A
4way flasher/indicators 5A
Lights have been modified with relays as per "Let There Be REAL Light by Raymond Carbone" article; including recommended fuses.
The only lines not fitted with in-line fuses are the connections to the ignition switch and the overdrive.
Any comments on the sizes of the fuses would be most greatfully received but my real question is, that now I have fused all the lines, would it be appropriate to reduce the size of the 50A fuse and if so what would be an appropriate size.
Thanks
AJ
Wiper 15A (10AGC)
Brake/Tail Light 5A
Heater fan 7.5A
Thanks
AJ
Hi Guest!
