I need a small ,maybe 6 fuse panel with a couple of relays added in.
How about some links for vendors. I would like no wires on it and a single power input.
Looked at Painless already ,they have wires
Thanks
How about this one?
They have real good prices on relays and sockets too...
NFI -- but I just ordered some stuff from them and they were nice to work with.
Thanks for all the responses guys. Found something in the area with all you guys in mind. When I went to really tear into what I had ,boy was I screwed up.
It turns ou I need a live feed and a switched feed on my panel. The relays and one fuse where battery feed and the stuff for the computer turned out to be switched.
SO
Plan B
When I needed something similar to that, I used two MGB fuse blocks. One for switched power and one for constant. Ran the fuel pump and fan relays from them as well as many other aftermarket electrics.
Its too bad you didn't consider the Classic Technologies fuse box. It was designed specifically for TR6's but work with MG's other Triumphs, etc. It comes with wire with the proper stripes and color codes, bullet connections and just about everything necessary to do the installation.
