On a TR3A, does the Furflex Door Seal go all around the door (except across the top, of course)? Does it mount between the door and the door panel, held on by the panel mounting screws?
No, a long piece runs along the A post from the scuttle all the way to the bottom and is mounted behind the foot-well trim panel. A smaller piece runs up along the B post and is mounted behind the dog-leg trim panel. All the rest are small rubber seals attached by clips.
Yes there's no Furflex on the doors at all. Near the top of the door is a length of contrasting piping between the door card and the capping. Along the underside there's a rubber seal as Joe described. Often the repro rubber seals are too thick and cause door closing problems, in fact I gave up bothering with them. No dust or water gets in as a result.
