G
I don't know if anyone is interested but I thought it was worth mentioning. Pep Boys sells a fully retractable antenna that is almost an exact replica of the OEM antenna that was on my Spitfire. Same shaft size and length, same tube size and length. Even the dressings around the mount to the fender were exact copies. The only difference was the top tip has a spot for the 2 little keys that they give you with it. Opens and closes nice and smooth all the way into the fender. Best of all...$11.99
