19Sprite65
Tired of the body work, think I'll get the front suspension as a change of pace. I'm having trouble unscrewing the fulcrum pin to separate the lower link from the swivel pin. The cotter pin came out with a little heat, PBB, and patience. I've removed the screwed plug, cork rings and followed the same procedure, but it appears to be stubborn. Do I need to remove the pressed-in plug?
