BruceAllcorn
I'll try to keep this short - went for a drive, got back home, turned the ignition key off, car kinda backfired and then shut off as it should. Tried to restart, but to no avail. The engine turned over but didn't even attempt to fire. This much I know - timing is OK, have proper spark at the plugs and have fuel at the carbs. Rather than pulling off the air cleaners, I pulled the vacuum line off the rear carb, sprayed a little brake fluid, hit the ignition switch and the car fired (probably on just 3 cylinders). Therefore, I'd bet that something to do with the carbs has happened and they are not taking in and distributing the gas as they should. The spray was used on the rear carb only, but the front carb must not be getting (enough?) fuel either. So the question is - stopped up fuel line starting at the first carb? - not enough pressure from the pump? - any ideas/suggestion would be appreciated.
Thanks,
Bruce
Thanks,
Bruce
