john ahern
Hello everybody, I'm a new member just getting started on a 1963 Austin Healey 3000, MkII. I'm currently looking for help in determining if the fitting going into the fuel tank is generally welded to the tank. Mine looks like it may be. The uptake from the tank is clogged (maybe with slushing compound applied in the past), and I'd like to remove the fitting to get at the pipe inside the tank. I've tried air to blow back, and tried fishing a stiff electrical wire without success. Anybody have any knowledge if the fitting is removable (i've gingerly tried a pipe wrench without success), or have any alternative suggestions?
Thanks for any help you can giveshort of buying a new tank.
John
Lady-l@msn.com
John
Lady-l@msn.com
