TR4/4A Fuel tank paint?
mtlman8
Hey all, So my fuel filter kept getting clogged with rust, so I pulled the tank and cleaned it with CLR. With the exception of some light surface rust the tank is pretty clean. My question is, has anybody had success in painting the inside of the tank? What kind of paint will work?
That seems risky to me with the doubtful benefits vastly outweighed by the problems you'd have if the paint failed.
If your tank is 'pretty clean' after 50+ years of use then why do anything more than keep it fairly full most of the time?
Look for "slushing compound" sold by several LBC vendors. It's basically just a special paint, meant to be applied with little surface preparation and resistant to gasoline/ethanol. But make sure you get the current formulation; some of the older ones wouldn't stand up to ethanol and starting coming off in big sheets.
I'm with Geo, I just leave mine bare. The sediment bowl on the fuel pump catches 99% of what little rust comes out; and I change the paper element filter every couple of years.
PS, this is after several years of daily driving.
If you want to line the tank look online for the kits Randall mentioned. Having used a couple I will suggest the POR-15 motorcycle tank lining kit. Though it says it is for motorcycles, there is enough material in it to coat up to about a 10 gallon tank.
That being said, if the tank doesn't have any holes I would not line it. Using the liner kit may create more problems than it solves. Your CLR treatment is good. If you want to be doubly sure, clean the tank first with a strong caustic cleaner (I like ZEP Industrial degreaser concentrate from the home center). Add some old nuts and bolts to the inside of the tank and slosh it around every so often. That will remove gum and varnish from inside the tank. After several hours of sloshing the caustic cleaner around, rinse the tank with water and repeat with CLR or phosphoric acid. After several hours, fill the tank with water (leaving the CLR or acid in the tank) and allow it to sit for a day (full day) then drain and dry the tank. The CLR or phosphoric acid will dissolve or loosen the rust scale. Don't forget to take the the lose nuts and bolts out of the tank.
I cleaned it again with apple cider vinegar and I'm happy with it. I think I'll just rinse and call it good. Thanks for the input.
The inside of my tank was rusted and I used the Eastwood product(s) to clean and coat. It's not leaking, looks very clean inside and so far no problems. It is a very time consuming project and you're left with some chemicals to dispose of. -and it's not cheap. If I had to do it again, I think I'd get another tank.
