Nunyas
Hi again folks,
Fisrt off, I'd like to thank those that gave me pointers on my brakes causing my idle to go up issue. I pulled the servo assemly, after I got the parts and immediately found that the vaccume seal between the servo and the master cyclinder was installed incorrectly in the past. I replaced it and I think it's fixed... for now.
However, in my testing of the effects of applying my breaks I encountered a new issue. Although, I'm not entirely convinced that it is new. In my thread about my brakes I mentioned that I could not sustain "high-way" speeds (i.e. 60+ MPH for more than a minute or two) without my B acting like it stalled and then picking up again a second later. The car has also been stumbling off the line. Over the past week starting from a dead stop has become more and more difficult. Starting the car period has become alot more difficult since I've acquired it, most noticeably over the past week. While poking around under the bonnet, I noticed that my fuel filter looked like it barely had any fuel in it. It seems kind of odd to me for it to not be full of fuel at all times. While checking my brakes in my drive way the car stalled, and starting it is like trying to start a car that has not fuel. However, the tank was just filled recently, and the guage still reads 1/2 tank. I can hear the fuel pump clicking when I turn the power on in the car, but I don't always get rapid clicks that slow down. Right now, all I get are slow clicks that average about 2 clicks every 5 to 10 seconds. Watching the fuel filter under the hood I see no new fuel entering it at all anymore. I checked under the car for spilled fuel (incase a line has been punctured) but I did not see any wet spots on the ground at all.
I'm thinking that my fuel pump may be bad, but the clicking from it makes me think that it could still be working, and I might just have some sort of blockage in the line. The pump that is currently in the car is definitely not an original, as I can see the hackish work that was done to install it. The gromet in the trunk above the pump is missing and I can see the wires for it were spliced into the harness.
Are there any "common" points to check in the fuel lines for blockage? Also, do any of you have any recommendations for replacement or even performance parts? And lastly, is there anything else that I should check in the fuel sytem before I go running off to buy new parts?
Thanks again for any information you guys can give me. /ubbthreads/images/graemlins/smile.gif
