Any thoughts on the following issue would be most appreciated.
Have been having fuel starvation problems on my 100 for about a year. I've: 1) replaced a suspected gummed-up steel tank with an aluminum one, 2) installed a double ended SU pump wired as two separate pumps, checked the carbs and pulled out most of my hair. The gas line(s)are open, lots of fuel to the carbs, but from time to time, usually when I'm max distance from home, one or the other float bowel dries up. I know it sound like the float level adjustment, but I've got the "fingers" up so high I'm surprised there isn't gas puring out. I also run grosse ball-jets, that are working fine (as tested by blowing into them and moving the "fingers" up and down. Sometimes it's the front float bowl that goes dry and sometimes the rear. Ususally at speed. Tonight it started to pop and bang on me on the interstate at about 65. Rear float bowl almost dry when I got home and took it apart. "adjusted" the "fingers" all the way up, reassembled and it ran like a striped-ass ape up till about 75mph, and then putt-putt, bang-pop. After slowing down, it ran ok, but under any amount of acceleration, it was fuel starved.
Any ideas?
Also, Michael Oritz...if I can make it run, I'll be at BOG on Sunday. Hope to see you there.
Jeff Maynard (red 100 at Hunt Club last year)
Any ideas?
Hi Guest!
