I moved my TR out of the garage so I could do some work on the bride's car yesterday. When I tried to start the TR to put it back in the garage it would not start. I went through the normal checks. Spark, gas etc.
There was no gas getting to the carburetors. The fuel filter was one of those glass units that you can see the fuel in the filter. There was some crud in the filter but there was gas coming out. I changed the filter anyway and put every thing back together. I still got no gas out of the pump when I cranked the engine. I went to the book to see how much a pump was going to cost and went back to the garage to remove the old pump. I saw gas at the output port of the pump. I cranked the engine and behold, gas spurted out of the pump. I put everything back together and the car started right up.
Now, after this long story about a simple problem, I am wondering if I should go ahead and replace/rebuild the fuel pump or does it just take a while for the fuel to work it's way to and through the pump. I have not had this problem with the old domestic cars that I have worked on.
Thanks for any help, Pete
