Recently replaced fuel tank. Got connections correct on pump but still get no gas to carbs. I suspect pump is bad. Could blowing back through lines with air line (90 psi)when blocked while still connected to pump have caused the diaphragm to go? I get nothing out of the pump at all. It is aftermarket replacement and runs all the time (I think they call it a legacy pump though shaped like the SU and fits into the rear compartment on a 76B.
