Just received the Carter pump and the Holley regulator (pictured with old Mitzu pump):
I'm waiting for my "Painless Wiring Kit" (lazy, I know) and my pressure gauge:
"Pressure Gauge, Low Pressure Diaphragm, Dial Size 2 1/2 In., Range 0 to 5 psi, Dial Size 63 mm, Connection Size 1/4 In NPT, Connection Location Lower, Graduations 0.1 psi, Accuracy +/-1.5 %, Case Material Steel, Case Color Black, Socket Material Brass, Tube Material Beryllium Copper, Lens Material Polycarbonate, Operating Temp. Range -40 to 140 F"
Next step is a stop to Napa to try and find appropriate fittings to make all these work together. The fittings on the old pump are quite small (~1/4"), so should I find fittings of that size, or change out the fuel lines to accommodate larger fittings?
Also, the gauge will be used to set the pressure, but it will not be left in place. Is there a fitting available which would allow the gauge to be "quick" attached/detached, or is a plug going to be needed?
Any thoughts on all this in general?
Thanks!
