Yesterday we took the Healey to San Jose (about an 80 mile round trip) to visit some family and attend to a few errands. Into the trip the fuel gauge was reading about 1/4, which usually is fine, but the car apparently ran out of gas--it did the pinging followed by the dead throttle. So I coasted into the filling station down the hill and put in 11.9 gallons. That didn't seem quite right. And I made sure I had topped off the tank. But the engine cranked right up. However after a hundred yards and waiting through a red light, no joy. I pushed it into a parking lot and investigated. Initially I considered the problem to be a clogged filter, which can easily happen when running a tank dry. But 11.9 should not be dry, right?. I have a clear in-line filter between the tank and pump, which upon inspection appeared not clogged. I disconnected the hose from the downstream end and back-blew the line. No clog. After reconnecting the fuel line to the input of the pump, I disonnected the output from the pump. Clicked on the key on and got only a buzz, but no fuel flow.
The pump I have is a linear flow Carter aftermarket unit about 4.5" long by 1.5" diameter. Seen 'em at NAPA before, and figured they'ed be close by if I needed one.
So I went to the NAPA store down the street and picked one up. Took less than five minutes to install all the problems are solved.
I'm curious now, though. Is the top end running stronger now and perhaps I was having some fuel starvation probems all along, or is it just my imagination after spending $54? (my field testing is limited since I don't tend to run WOT under load on a 50 year old crankshaft)
Oh, well. I will just smile and drive on. Problem solved.
