Fuel pump costs?
jlaird
FRA Model Features:
· Flow to 87 lph (23 gph)
· Pressure to 8 psig (54 kPa)
· Maximum current requirement: 2.0 Amps
· Reverse Polarity Protected
· 12 or 24 Volts Available
· Self priming
· Dry lift to 24" (61 cm)
· Output Pressures Available: 4, 6, 8 & 10 PSIG
· Compatible with all commercially available pump grade gasoline,
gasohol, diesel or bio diesel
· Continuous duty life (diesel fuel): >5000 hours
· Dry run: To (2) hours
· Overall height: 5.35" (136 mm)
· Overall diameter: 2.76" (~70 mm)
· Pump centerline to base of mounting bracket: 1.58" (40 mm)
· Mounting bracket width: 3.0" (76 mm)
· Dichromate or E-coat external finish option
· Weight: 1.56# (0.71 kg)
· U.S Coast Guard Test #16623-1 and #16623-2 Certified
· European Standards EN 61000-6-2-2001 and EN 6-3-2100 approved
Retail Price: $3.00
Our Price: $3.00
Biff
So Jack where is this pump available?
Inquiring minds would like to know.
Price seems a little low for what it offers.
It would cost more to ship it than what it costs!
Specs and size are similar to a pump I purchased at Advanced Auto, that is, except for price. AA one was like $30.00.
Is this a Facet(sp?) pump from one of the aircraft suppliers?
jlaird
jlaird
Oh sorry, that is an outfit called AutoPulse, Cass City Mi and yep they will sell one.
I pulled one from my Bugeye, still works, was made 6/75.
https://walbro.com/
Autopulse... isn't that the name of an old type of fuel pump. I remember them being used on old John Deere lawn tractors.
GB1
Trevor, based on the web page, it could have been, and that is why "nothing reuns like a deer". /ubbthreads/images/graemlins/thumbsup.gif
Patrick
jlaird
jlaird
Output pressure available at 4 lbs which may not be perfect but would work if carbs were in good shape.
I had a holley pressure regulator set to 5 lbs when I first got my car, and it the carbs held fine. I eventually switched to a lower pressure pump, so I do not know how long the carbs would have continued to hold.
Quote from David DuBois on mgcars bbs:
"I am the type that wants the original pump in our cars, but that is just me, if originality is not a big thing for you, then go with the cheaper, after market pump (just don't go with the Auto Pulse or MoProd pump that is made in New Zealand. It is a good pump, but it is made of plastic and develops cracks around the inlet and outlet ports over time)"
jlaird
jlaird
Could not agree more Trevor, I just though it was intresting that the fuel pump still worked, the company was still in business, and still selling pumps for 3 bucks.
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
