jlaird
FRA Model Features:
· Flow to 87 lph (23 gph)
· Pressure to 8 psig (54 kPa)
· Maximum current requirement: 2.0 Amps
· Reverse Polarity Protected
· 12 or 24 Volts Available
· Self priming
· Dry lift to 24" (61 cm)
· Output Pressures Available: 4, 6, 8 & 10 PSIG
· Compatible with all commercially available pump grade gasoline,
gasohol, diesel or bio diesel
· Continuous duty life (diesel fuel): >5000 hours
· Dry run: To (2) hours
· Overall height: 5.35" (136 mm)
· Overall diameter: 2.76" (~70 mm)
· Pump centerline to base of mounting bracket: 1.58" (40 mm)
· Mounting bracket width: 3.0" (76 mm)
· Dichromate or E-coat external finish option
· Weight: 1.56# (0.71 kg)
· U.S Coast Guard Test #16623-1 and #16623-2 Certified
· European Standards EN 61000-6-2-2001 and EN 6-3-2100 approved
Retail Price: $3.00
Our Price: $3.00
· Self priming
Retail Price: $3.00
Our Price: $3.00
