mrsprite
My Bugeye has a Datsun A15 engne in it and I'm running an electric fuel pump that I got from NAPA. I just installed a Holley pressure regulator with guage and it shows ~2.5psi max (this is with the regulator adjusted all the way for max pressure). According to the Datsun manual, I should have between 3 & 3.8 psi, so my question is what ill effects (if any) will running the pressure too low be on my car?
I am thinking about getting a higher pressure pump (7psi) and regulating it down to around 3.5 psi. Any problem doing that?
Thanks.
Thanks.
