I'm assembling the oil pan to block on my 66 BJ8. There are two small clips that are attached to the block by oil pan bolts, longer than the others, that protrude through the lip of the block long enough to secure the clips with washers and nuts on the protruding part of the bolt. My problem is that I don't know exactly which two oil pan bolts should be the longer ones used for the clips. Starting from the front, any idea on which ones are correct?
Thanks in advance.
Thanks in advance.
