I have gone back through the Search engine and I am still having trouble determining the fastest and easiest way to distinguish between a fuel startvation issue and an electrical issue.
I am pretty inexperineced with working on TR's (I prefer the driving experience vs. the mechanic experience), so bear with me as a describe the situation. You may recall recently that I had complained of my 61 TR3A running rough. Well, it finally died. Let me describe it.
For a while it was running as if it was being starved of fuel or that it might be misfiring (I find it hard to tell the difference). Recently while I was driving, it really got rough (jumping and jerking quite a bit - felt like I was running out of gas, although it is full), so I turned around to head home. It finally died. I got it to start again, went about a quarter mile and it died for good. Had to get it towed home (a measily mile - yea AAA!).
Current symptoms are that it will just crank, but will not fire. I would think electrical, but I find it weird that it died on me, then I was able to start it, then it died again. Electrical things (in my mind) either work or they don't. Fuel / mechanical things can "sort of" work as they go from the working to failure modes.
Things worth noting. It does smell like gas after I crank it a while. The fuel filter does have gas in it. It looks pretty clear to me. The choke appears to be working, at least on the surface the mechanism seems to be doing what it should. the car is negative ground. My coil has + and 1 on it and the - goes to the points (which I think is correct). Nothing "looks" wrong in the distributor cap (we will hook up timing lights, dwell meters, check resistances and voltages later today).
Anyway, long story short, I have a neighbor who is willing to help, but I want to try to eliminate things as fast as possible. If this was your situation, what would you check, how would you do it, and in what order?
A huge thanks in advance for your help.
Bryan
Bryan
