TR6 fuel lines for 69 TR6
ichthos
Hello,
I am trying to figure out how the fuel line is attached, including where the brackets attach. My 69 TR6 is still stock. I need detailed pictures from the fuel pump around to the carbs. Does anyone have pictures the fuel lines from the right, left, and front sides? If not, is there a website that I can download pictures? Thanks, Kevin
The Moss and VB catalogs may provide clarity or the Rimmer Bros website. As I recall the fuel line is attached at only one point between the fuel pump and front carb, near the thermostat housing I believe.
Thanks for the information. From the Moss catalog it looked like the fuel line was only attached in one place in the front as you said, but I wasn't sure. Would you happen to know exaxctly where it is attached in the front? I have found many pictures of TR6's on the internet, but none with any detail in this area. If I had one picture of the front of the engine, my problem would be solved. I know I am making more of an deal out of this than I should probably, but I am nervous about placement of the fuel line since it follows so closely to the engine.
Kevin
