HAN8L1965
Went to go for a drive today, extremely hot in Ohio 85-95. Started car started right up then it started to stutter. Looked at my clear fuel filter at front just before carbs, very little if any gas coming forward. I have a facet fuel pump it is chirping away as usual I also have a filter before the pump. It cleared up after 10 to 15 minutes took a ride around the block fine. Headed down the raod 3 miles later a couple back fires and that was the end. Waited a few got her started got her back home still starving for fuel.
So 4 hours later I go out turn her on and she starts right up look under the hood filter has the regular amoount of fuel flowing let rur for 15 to 20 everything is right.
??? Is this vapor lock? last time car was driven it was quite hot outside and I had driven it about 2 hours in the heat. Brought her home shut her down, graeat drive.
If it is vapor lock what creates this situation? The little woman was not overly excited sitting at the side of the road but as I said to her Its only 3 miles back.
Mark
Mark
Hi Guest!
