installed new aftermarket fuel tank in 1961 BT7. The fuel line going through the backwall of the trunk to the tank is too short. I will need to bend up a new fuel line from the pump to the tank. How can I go about specing out the right fuel line and fittings?
Hi, Fuel tank outlet, if original, should be 1/4" BSPPT (British Standard Parallel Pipe Thread). It needs a 60 degree cone seating with a nut holding it in place. There are adapters available to use an AN fitting. Pegasus Racing has a pretty good overview (www.pegasusautoracing.com) . Good luck, Bob
