bugedd
Upon tinkering with the idle adjustments I noticed a fuel leak from a compression fitting, which makes me want to delete the hard lines in favor of regular fuel lines. I am confused however, as to where the lines are to run.
From pics I have seen, the line at the bottom coming off the regulator should be feeding into the fitting that is currently not connected. Then the line that is connected to the float bowl currently should go to the other float bowl. The "T" you see before the first carb is where the leak is. Any reason why what I am finding as the inlet connector is bypassed? And should I run the line from the regulator to this? Thanks in advance, I have a meet Sunday and need to get this fixed asap.
Hi Guest!
