MGB Fuel in the oil
drooartz
So onto the next thing to sort out with my MGB. Since the engine rebuild (2 years ago, maybe 2500 miles) I've noticed that the oil level was occasionally going up. Not good. Car has been off the road for a year so hasn't been driven much since I noticed this.
I drove the car about 100 miles last weekend. The oil level before I set off was about 1/2 between the min and max levels. When I checked the day after the oil level was up over the full mark. So I have an issue somewhere.
To see what might be going on, I sent an oil sample off to Blackstone labs for a looksie (before last weekend's drive). The report back showed 0 coolant (woohoo!) but did show some fuel in the oil. Not more than they consider problematic, but it was present. Their comment was that if the level keeps going up, to check the fuel system. So here I am.
Where do I start looking?
Thats a tough one, since the most obvious and common method of getting fuel in the oil is themechanical fuel pump with isn't part of the MGB's system. Does it happen while you're driving, or after being parked for a while. If it happens while parked, I'd suspect fuel dripping into the cylinders through the carbs and past the rings - but even that seems unlikely because the float bowls on the SU's are below the jets, and once the key is off there's no pressure to force fuel past the bowls. If it happens while running, then possibly a bad valve guide seal on an intake valve allowing fuel to enter the crankcase but normally the vacuum of the intake would cause it to suck oil out instead.
The fact that he level goes up substantially on the stick overnight makes me still think about fuel seeping thru the carbs into a cylinder, and then getting past the rings. That seems like more fuel than could be accounted for in just the float bowls. Is your fuel pump somehow accidentally wired to an always-on power source where its possible to be slowly pushing fuel past the float valves over the course of the night?
Does seem to happen after a long drive. I did check the car once during the drive last weekend and the oil level was still OK if I remember correctly, so I am thinking it's from sitting after a drive. I don't think the pump is wired incorrectly, but I'll have to check it. I've not touched that wiring, though the shop that did the work on my car (curse them) may have. Easy enough to check
I was thinking something in the carbs as well. Hadn't thought about the fuel pump. Could the gas tank be getting pressurized somehow and causing the same thing?
I'll dig into later this week or this weekend. Thanks for a few things to look for.
I don't know if this is related, but that drive last weekend was about 40 miles one way. When I got to that half way point, the car seemed to diesel when I shut if off, took a little for it to actually stop running. May be unrelated, but that is not a normal thing for this car.
Pressure in the tank? Possible - easy to check by taking the cap off. Other thing you could try would be to disconnect the fuel line right at the carbs when you park (stick the end in a small glass or metal jar/can - nothing that fuel will dissolve), and see if you end up with fuel there over time?
That's a good idea. I'll give that a try when I get some time.
A bit of an update. Sent my carbs off to Joe Curto for a rebuild. I figured this would remove one variable as I’ll now know that the carbs should be good to go. He’s got them done and they should arrive on Friday. Not sure when I’ll get them installed, but hoping to get to it in the next week or so.
Because pics are fun. Rebuilt parts ready to go on, though it figures that they come in a month where I have little time.
fortunately they are simple to assemble and simple to install and reasonably simple to set up.
Top Tip - remember that if you disassemble and assemble two SUs enough times you will end up with three carbs. :D
Hoping to (maybe) take a little time off work this Friday to work on it.
Small update, got the carbs loosely installed tonight. Hoping to get everything buttoned up on Friday if I can take the time off work. So far they look very good.
Sadly looks like I won’t get back to this until maybe some night next week. So close to firing up, but I’ll have to be patient. :wall:
Last Friday was a big day. Was able to take the day off work and spent the morning working on the MGB. Got everything connected and tightened up, and the car started!
I got the linkages adjusted and set the idle, and it runs well. Left everything else setup as it came from Joe Curto, and so far so good. Will need to drive it more to see if this has solved the gas on oil issue, but it is running well and actually starts easier now.
As a bonus I drove all 3 in the same day. That may be a new world record, a singularity in the universe.
Well $#!^
Oil level up just past the “M” in MAX. Was on the line before driving it, only maybe drove 20 miles after the oil changed. So I have now changed the oil again and sent a sample out to Blackstone Labs again to confirm if this is still gas in the oil or something else.
If it is still gas, I’m now confident that the carbs are in good shape and working as intended. So that leaves me with?
Fuel pump over pressuring (it’s a stock or similar pump, same one in the car as when I bought it in 2011)?
Blocked tank vent causing overpressure?
Bad gas cap also with overpressure?
Open to any thoughts or other things to check
Usually if you're getting gas in the oil its because its getting past the rings as a liquid, which is unusual to have happen while the engine is running. If you were getting coolant in the oil (much more common to happen with the engine running) you'd know it real quick because it would look like mud not oil. I'm at a loss but very curious as to what the lab report tells you.
Me too. Really hoping it’s not rings, as this engine only has maybe 2000 since a rebuild. Really don’t want to pull it, but it will be what it will be. I’ll report back once I have the report.
A little gas in the oil can be attributed to running too long with the choke pulled out, or significantly rich setting while underway, but it would take A SIGNIFICANT amount of fuel to raise the level!
I don't know what kind of oil you're using__does it expand when heated__but before you do anything drastic, check the oil when it's cold/sitting overnight. Go on your usual test drive, and check the oil the next day to see if the level has gone up.
For diagnostics, my Go To is always a leak-down test, supplemented with dry/wet cranking compression test, depending on findings from the leak-down results.
If the Blackstone results don't show a worrying amount of fuel in the oil, the level is not going up because of fuel (and you'd SMELL IT if there was THAT MUCH gas in it).
Got the Blackstone report back yesterday. No notable fuel in the oil, and all else looked good (no coolant in the oil, no other concerns). So now I’m confused.
I’ve had this car since 2011 and have used Valvoline VR1 20W50 consistently since then. The engine was rebuilt about 2500 miles ago, and this rising oil level thing started after that. I’m doing the same oil change procedure I’ve always used. Oil pressure is about 70psi when hot.
Last night I drained off a bit of oil as even the new oil fill was over the line, got the mark on the dipstick to about 3/4ish full. Took it out for a 70 mile drive. Will check it when I get home.
I also popped the gas cap when I got home, no pressure build up.
So it looks like it’s not fuel. I’m still a bit stumped. Really want to understand this, as the car is otherwise running well and I’d really like to be driving it.
All of our British cars LEAK oil - yours is somehow creating it. Perhaps some sort of cosmic wormhole where all of our missing oil is collecting in your engine similar to the socks in the dryer?
Bad jokes aside, that is very confusing. If you're not losing coolant into the oil, and the fuel is not mixing with the oil - then what is? Matter does not normally spontaneously create, and if it does the odds of it coming into existance in the form of perfectly refined 20-50 multigrade oil are effectively none. There is no path for
oil to transfer from the transmission into the engine.
Somehow I have invented the inverse-LBC. :bananawave:
I’m very curious to see how the oil level is when I get home today. Prior to the carb rebuild it would keep going up, so not just after an oil change. It’s possible I just filled too much, that the oil was just really slow to get from the filler to the sump and show up on the dipstick.
What I remember from pre-engine-rebuild is that I could fill through the filler on the valve cover, and the dipstick would reflect that added oil very quickly. Maybe it’s just a lot slower now with the rebuilt engine? I’m grasping a bit here.
