So if you have it wired up....and don't forget the ground on the gauge.....if you remove the wire to the sender, that is infinite resistance....gauge will read full.
If you ground the wire to the sender, that is zero resistance, and the gauge should read zero.  Only do these test momentarily ....otherwise bad things could happen!
In reality....."0" ohms is empty, and 80 ohms or so is full. Cheers,
Scott in CA
