Hello Everyone, I have a guestion on my fuel gauge. I'm checking continuity on all my circuits as I am fusing the new system. With the sending unit wire disconnected and not touching anything, should i be reading continuity to ground from my input wire to the gauge. Some clarification of the circuit is that this particular circuit in my car is wired as in the early 100/6 cars. That is the power source comes from the fuse, then to the fuel gauge, then continues on to the Heater Switch then to the Heater motor. During this test, the heater switch is in the off position. Oh, also the source wire is removed from the fuse box. Thanks, Dave.
Hi Guest!
