DavidThorn
The car is a late BJ8, suddenly the fuel gauge has deflected to full, and beyond.
I have taken the cover off the sender unit. All seems OK the float is moving properly the "probe" is about halfway along the coiled wire resistor which is correct as the tank is about half full. The sender unit has a good earth.
Have pulled the dial out of the dashboard, but seems connected properly and it has a good earth.
Every connection I check, apart from earth obviously, is giving a full 12-volt reading.
Any ideas?
David
Any ideas?
David
Hi Guest!
