Since I got my Spitfire ( Sabrina ) I have had a consistently low reading fuel gauge. Full tank, gauge reads just below 3/4 full. So far I have replaced the gauge 3 times, swapped
The voltage regulator and inspected the fuel float, which is intact. Float arm is free and has full range of motion. Grounded the sender wire and still get the same result. I am beginning to believe that the wire between the tank and gauge has an issue. Thoughts and suggestions would be welcome at this point. Next step I guess would be to run a new wire between
and see if that makes a difference. Not a big deal really, but one of those small things that bothers me.
