Fuel Gauge - Help Needed
andrewss
I have installed a much larger alu fuel tank in a BN1 100/4. The fuel tank has a side fitted fuel sender which was copied from the jaguar XK140/150 fuel sender. It has two connectors (I believe one to measure the actual fuel level and the second for measuring the reserve tank which i don't have).
I have standard Smith's fuel dial. The two do not seem compatible !! Both the sender and the gauge are earthed and wired correctly. From both the top and bottom contact on the sender i am getting a full reading which I know is not the case as the fuel tank is near empty...
Do I need to find an alternative fuel gauge ?
Any help appreciated...
healeyblue
The sender may not have the correct ohm range. Is the gauge stock? What is the sender for? The MGB also has the sender in the side of the tank.
dh100m
with the old tank the sender body is grounded ,if the grounding is bad ie open circuit the gauge will go full scale try grounding one terminal of your new sender
Here's my setup; I used the aftermarket replacement sending unit for the Healey's tank. One (1) wire is all I needed to make it work. The gauge reads "full" until the level gets down about halfway, then actually starts responding to the level in the tank.
Everything worked like a charm for over a decade, but the resistor has recently taken a dive__I'm waiting for the level to get low enough to get the sender out and see what's up.
In your case, what happens when you "ground" the (one) wire from the sending unit? IIRC, the gauge should read "full" (or "empty?) and as the resistance goes up, the reading on the gauge goes lower (or higher?). The gauge being merely a voltage meter, where "full" (or empty, whichever the case may be) equates to it getting the full 12VDC (no resistance in the grounded feedback wire).
blueskies
Both the Jaguar and Healey gauges should be magnetic gauges. If everything is wired and grounded correctly and both parts are good, the gauge should work, at least somewhat - even if the ohm ranges of the Jaguar and the Healey sending units are not identical. Both likely register 0 at one end of their range and 80 to 100 ohms at the other end. The second terminal on the Jaguar sending unit may be for a low fuel light that comes on when the level drops to a certain level, and not for a reserve tank gauge; that should be completely isolated from the fuel gauge function.
A
andrewss
Update - both the sender unit (measured the resistance whilst moving the float) and the gauge are working well independent of each other. As healeyblue highlighted I think the problem relates to the Ohm range which seem to completely different. I need the XK150 sender unit as its the only one that has a long enough arm to reach the bottom of the tank.
So taking that as a given can anyone recommend a compatable fuel gauge preferably 'Healey looking' ?
Regards,
Andrew
healeyblue
Measure the Ohm range of the sender you intend to use. Its easy to do and is a value you will need to know to make your selection for a gauge.
catfood
Try googling spiyda design. They manufacture a box of electronics that provides the calibration for you. Not used one myself but a friend has had some success in a kit car he buil
A
andrewss
The fuel sender operates between 80 ohms empty and 2,2 ohms full. The only make/model that I can find thats suits this sender is a VDO Series 1 that has an operating range of 0-90 ohms. Its not a Smith's but I guess I don't have a choice unless the Smith's can be re calibrated..
TimK
I have used Nisonger for my speedometer with great result. Easy to check with them about recalibrating the fuel gauge.
CraigC
Andrew, I brought a variable potentiometer home from work today in order to test the gauge in my BN2. I will try to get to it tomorrow and post results.
CraigC
It's actually 0 empty, 90 full. This is a commonly used resistance profile. Being that this is the exact opposite of what your sender measured, I would think you should be able to rotate the sender mounting position 180 degrees to achieve the needed operating resistance. Looks like the stock 6-bolt mount pattern by the pic in your first post. Could you post a pic of the tank as well as of the actual sending unit?
A
andrewss
Craig - Thank you so much for taking the time to check for me. Your solution will indeed work. I will post a picture of a 'happy man and a fuel tank' later today..
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
TRclassic3 TR2/3/3A Help with fuel gauge blowing fuse Triumph 6
J TR4/4A Fuel and Temp Gauge NightMare! Help! Triumph 24
G BJ8 Fuel gauge help Austin Healey 8
I TR6 TR6 Fuel gauge help Triumph 7
S Wedge Help with TR7 Fuel Gauge replacement Triumph 3
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
