Fuel Gauge always shows 1/4 full
warwick-steve
Another fuel gauge query! - can you help please
When I turn on the ignition my fuel gauge needle swings over to 1/4 full and stays there irrespective of how much fuel is in the tank.
As the gauge is not completely dead as it appears to be getting some current flow how do I go about identifying whether the gauge needs attention or the sender is stuck in one position? A new aluminium tank was fitted in 2011. The gauge has been like this since I bought the car 3 years ago and was a problem for the PO.The gauge is definitely earth connected.
Thank you for your help
Steve
warwick-steve
warwick-steve
Steve and others
A grovelling apology
Having put off this job to do other more urgent Healey tasks I forgot that I asked basically the same question some time ago and have the information you advised at the time, So sorry about that. A senior moment - again. No excuse now I will get down to resolving the problem.
Steve
RDKeysor
Bronze
I pay attention to what Steve writes, and he writes a lot. My fuel instrument indicates full when it is full, but it registers empty with perhaps four gallons in the tank. It has a ground wire and the proper orientation. I carry a graduated dowel to check the tank but still ran out a few months back. Years ago I bought a sender with float from JCWhitney for a Volvo and found I could bend the float rod to reflect the actual (more or less) amount of fuel in the tank. I looked at that possibility on the Healey a couple of years back and found I couldn't do that on my car. Have forgotten why. All that I have read about the danger of tinkering with the delicate wires in the instrument itself has discouraged me from looking at that end of the system.
Gliderman8
I had the same problem on my TR6... fuel gauge always showed close to empty. I found the original plastic float was full of fuel making it sink to the bottom.
I ended up replacing it with a brass float (from a Ford Mustang) and I have not had a problem since.
DTDuck
Steve
You can easily check the gauge to see if that is your problem. Connect a grounded wire to the sending unit side of the gauge. If your not sure which side it is use a test light to see which side is hot when the key is on (it will be the other side). When you have attached the grounded wire the gauge should read full when the switch is on. If it does, then the gauge is not the problem, the sending unit is.
Cheers,
Dan M.
steveg
Cheers,
Dan M.
If you can get a mirror up by the back of the gauge, you'll see one of the connections is labelled "T" as in Tank [sender]. The other is "B" for Battery.
warwick-steve
warwick-steve
Hi again
I checked the gauge and is appears to be OK. I connected a ground wire to the T terminal and the needle indicated "empty". I disconnected the wire to the sender and the needle indicated "full".
Removing the sender looks like a problem. It appears the old sender was installed in the new tank and that a translucent silicone type sealant was used. I would be worried about cleaning up the sealing face before fitting the new sender ie how to prevent bits of silicone etc falling into the tank. Looks like I may have to keep the measuring dip stick
Anyone know whether the retaining screws screw into threaded inserts in the sealing face?
Thanks again for your advice
Steve
John Turney
Do you have a ground wire from the sender case to a good ground? The sender case may not be grounded with that silicone there.
warwick-steve
warwick-steve
Hi John
Wouldn't I have the same situation with a gasket there? Actually not sure where the tank is grounded so will go and look.
If I do attempt to remove the sender I wonder if the silicone will peel off or whether I would end up picking at it with the danger of bits falling into the tank.
I will check the ground situation but if that doesn't help i'm inclined to keep using the measuring stick.
thanks
Steve
John Turney
Hi John
thanks
Steve
Yes, the same could happen with the gasket, although the silicone could end up in the screw threads. As Steve points out, the ground should be through hard fuel lines. I had to add a grounding wire like Steve did.
As for silicone bits falling in the tank, that's a danger either way. How you solve that problem in the future is to apply the silicone to the sender and let it sit for a bit to "skin over" before screwing to the tank. That keeps it from sticking to the tank.
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
P fuel gauge always full Austin Healey 2
livinginthepast 62 Sprite Fuel Gauge always on Full - Spridgets 9
T Fuel gauge always reading full Triumph 13
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
