I posted two weeks ago about my fuel gauge not working. With some help here I was able to confirm everything is working properly as far as "electrics," but I now see the problem.
In the manufacture of the float, the clamp around the base of the float was too tight and the float has a hole and indentation right there.
I can easily rotate the float so that the clamp is away from the crack.
I can order a new sender and float for $40 or so.
But can I repair that float instead? Any kind of fuel resistant epoxy, or other routine that would be worthwhile?
I'll get a totally refurbished fuel tank out of this process, so it's not all for naught. Just wondering if a float repair would be foolish. Draining and removing the tank again would make me a little grumpy.
thx
thx
