[ QUOTE ]
The bottom of your fuel pickup doesn't have a screen?
[/ QUOTE ]
Hi Tony,
No, my original tank did not have a screen & the new Moss replacement didn't either. With the Healey fuel pickups welded in as they are, You would have to cut the pickup out to clean the screen.
Interesting story - I replaced my original tank with a steel Moss tank. Mind you, I live in a dry climate & keep the tank full most of the time. Anyhow, about a year later, on a long road trip of course, the front inline filter plugged. Bypassed it until I could get a replacement filter at the next town. Popped the tops off the carbs & the bottom of the bowls were covered with red powder, about 1/8" deep, that had gotten in just in the couple of hours that I ran with no filter. Pretty sure it was starting to plug the jets as the car was starting to run lean & pulling the chokes let the stuff go through. This stuff went right through the built in SU pump screen. Cleaned the carbs, put in the new filter & all was well.
Got back home & cut the plugged filter open. It was filled with red powder. Looked in the tank & the surfaces were coated with red powder. This in a one year old tank. Never near moist air. Maybe the gas/alcohol mix that comes out of some pumps attracts water. Put a very large inline filter (Fram G3802A) between tank & pump. Replaced the front filter again & carry spares of both on trips. The tank hasn't gotten any worse or any better. The rear filter can hold a lot of rust powder. No more fuel starvation problems.
I'm sure that the older US made tanks were galvanized inside. The Brit tanks I got sure weren't. My mistake. If I ever change tanks, the next one will for sure be aluminum.
So you are correct, if the tank is clean & stays that way, no filter should be needed. I don't think I will have this tank "boiled" every six months & don't trust coatings.
