TR6 Fuel evaporating?
ceedub
If I leave my TR6 for a week or two without running, it is very hard to start. I am noticing that the fuel filter is just about empty after this time. Priming the pump with the little lever on the bottom of the pump does not seem to do much if anything to fill the filter. Is the fuel somehow siphoning back into the tank or would there be that much evaporation in that time. The engine is definitely struggling for fuel on startup. Is there a built in back flow valve in the fuel pump or would this be a needed addition to the fuel line?
poolboy
You won't be able to judge the effectiveness of the priming lever by looking into the fuel filter...but if you remove one of the fuel lines from one of the carbs and work the priming lever, you will.
And don't let the resistance or lack of resistance from the lever as you work it form your opinion as to whether it's working properly or not.
Geo Hahn
Typically the fuel filter will not appear full (is it half full or half empty? -- talk among yourselves and discuss).
Do you smell fuel in the garage? If not, you may be experiencing normal evaporation from the fuel bowls. If you do smell fuel there may be a leak.
If unsure... after a drive, try wiping under the carb with a paper towel (a brown one or blue one like many gas stations have is best) to see if things are damp with fuel under there.
3798j
Bronze
Two times with the GT6, it became really reluctant to start (it ran fine once it did start and started fine when warm). Both times a rebuild of the fuel pump got rid of the problem...and with a new diaphragm, that lever again had good resistance and moved fuel.
pdplot
My TR6 was doing the same thing, summer or winter. Adjusting the choke cable cured the problem. Now it starts in about 15-20 seconds cold, instantly when hot. Make sure you are getting full opening and closing.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
P XJ12 Fuel pump relay 85 Jaguar 4
