TR3driver
Great Pumpkin - R.I.P
Still shouldn't blow the chip, even if you short the output to ground. It is supposed to be fully protected (internal shutdown logic) against shorts and overload. Did you check that you are really getting 10.0 volts out?
Engine shouldn't run that cool, unless the thermostat is bad. Might be good to get some independent confirmation, like using an IR thermometer or even sticking a simple candy thermometer into the radiator filler neck.
https://www.harborfreight.com/1-inch-pocket-thermometer-46586.html
$150 is about right for a good TR3 gauge, either reproduction or original. Originals that still work are so rare that they bring close to the same price it costs to refurbish them.
One alternative is to pick up a cheap aftermarket mechanical gauge and use it at least until you get all the other issues sorted out. No one will mistake it for the original, but the look may not be all that bad. This one fit my TR3 dash and thermostat housing perfectly, no adapters required. Only modification was to hook up the light for it (one wire to the dash light switch).
I believe that's a Sunpro CP7975, and ISTR I paid around $25 at FLAPS. A quick search turned up this one on-line for $12 (plus S&H of course).
https://www.tooldiscounter.com/ItemDisplay.cfm?lookup=SNPCP7975&source=froogle&kw=SNPCP7975
