I have an adjustable steering wheel that won't adjust. I'm unable to even turn the adjustment nut below the steering wheel.
Are there any suggestions on how to break loose the nut and steering wheel?
If you really have to free it up soak it with PB Blaster ,give it a few raps with a wrench to set up a vibration to let the penetrating oil seep in. Let it sit overnight and in the morning carefully work the adjuster back and forth to free it up.
Interesting. I have a quart of acetone that's been sitting in the basement forever. I remember that it has a powerful smell? What dose PSF stand for? Maybe I'll brew up a concoction.:friendly_wink:
Sorry - PSF = Power Steering Fluid. Here's a copy of the original article comparing different penetrants. Note that altho' the article says ATF, the photo shows PSF, which is what Mr. Bender actually used.
