Hi Guest!
And how old are the rubber brake lines? They can fail internally. You can force brake fluid through them when you press the brake pedal. But when you release the pedal, the line is too restricted to allow the fluid to return.Do you think the drag is from wheel bearings or brake pads? Jon may be correct with the bearing being improperly preloaded but its' also possible the brake calipers have a little residual pressure and/or something on the pads that is causing slight drag. Try pulling the pads out and spinning the wheels to see if the problem still exists. Yours is a later car with a booster and I don't know if they have a 2psi residual pressure valve or not (it's common on lots of more modern cars) to combat 'pad knock back' to keep the pedal travel short. If your car has one, it may be malfunctioning.
If there is no difference with the pads removed, it's fine.With pads removed, spins freely. I sprayed the disc and pads with brake clean and installed.
New stainless hose. All brakes bleed fine, no air in the lines.
Spin is not equal to the passenger side. It just take a little more effort and wanted to look into it.
Thanks guys for joining in.
