front sway bar BT7
davidb
Looking for a little advice. I was planning at some point to replace the bushings on the sway bar that is attached to the front end of the frame. I recall that the last time I did this, if memory serves me, I had difficulty removing the rusty bolts that attach to captive nuts inside the frame. Some time ago, one of you good folks posted some photos of a new plate that you welded in at this attachment point, but I can't seem to find the photos, and they were excellent, and included a good explanation of the procedure. It seemed fairly straightforward, and was a good solution to the problem.
Anyone recall that those photos/that thread?
Thanks
DB
Thanks healeyblue,
I'll do another search under that subject. Your reference to Randy Forbes rings a distant bell...
Dave
