As per shop manual, I have the control arms, swivel axle, and shock installed. I inserted the two inch block between the shock and the mount to raise the assembly to normal load position, and then tightened the lower fulcrum pins and inserted the split pins.
The manual then calls for installing the spring, and lowering the car, then removing the two inch spacer.
Since I am assembling the car from scratch and I will not be lowering the car to the ground for a while yet, can I remove the 2" spacer before installing the spring? Otherwise it seems to me it will be very difficult to remove the spacer with the force of the spring on it. I suppose that I could just leave it until I am actually ready to put the car on the ground.
Your thoughts?
Thanks.
Lin
1960 BT7 in restoration
1959 Bugeye
Your thoughts?
Thanks.
Lin
1959 Bugeye
